Morning All!
I have recently started work on a commercial site with a company installing air-con, the system that I have questions on is thus;
35mm2 4 core SWA as main supply to the board, where the armour is used as a CPC, which then feeds 10 x 3 phase circuits, supplied via 1.5mm2 4 core again using the armour as a CPC. All of these cables enter on the same plate of a metallic water proof box and then off to the board inside.
I have been asked to replicate the above system with the other identical 'pods', that have already been installed, which house the air-con coils etc. The way in which the other pod/system has been earthed, is with a 35mm2 main earth from the main supply SWA to the MET, and the outgoing circuit SWA's have not been individually earthed, but have 2 earth cables, with a nut and bolt, near each bunch of SWA's linking the armour up to the MET, but not via a banjo but with a nut and bolt in the metal box. The metallic box has
been bonded to the MET.
So, is this arrangement ok, as the armoured is being used as a CPC in all cables and the cables are all located on the same metal plate, in close proximity, this guarantees earth continuity?!? Or, as I suspect, should each outgoing SWA have its own earth connected to the MET?
Thanks for your time, I hope this makes sense!
Stuart
Stuart
