K
Keef
Topic of much debate...
Is there reasons to fit the earth tag on the inside of the metal enclosure? The one about preventing corrosion does not wash with me as the enclosure is not IP68 rated thus cannot protect from corrosion inside.
I have always been taught to fit brass tag on the outside with a brass nut and bolt to prevent electrolytic corrosion. If you fit brass tag on the inside you get brass(tag)-mild steel(enclosure)-brass(tag)-zinc plated nut. Not a good mix especialy when adorned with another mild steel roofer!
Any oppinions welcome, this could be a big can of worms though. DISCUSS...
