SWA Internal Switch, best practice | on ElectriciansForums
Discuss SWA Internal Switch, best practice in the UK Electrical Forum area at ElectriciansForums.net
rrafluap
UK
Hi,
I'm going to be installing an outdoor socket, have no problem with the outdoor/socket side, but when bringing the internal end or the SWA into the property, need to be able to switch it. Only have hollow plasterboard void to mount fused switched spur to. But unsure of how I should terminate the armoured cable other than drilling into a plastic plasterboard box?
What is the best way to do this please?
Appreciate any help :)
Thanks.
I would take normal twin and earth to a box on external wall, joint onto swa there. Then swa is flat to wall rather than coming out wall horizontally and being bent at a tight angle.
No reason the joint box couldn’t be another socket, as it would be a fused down spur.
Reply to SWA Internal Switch, best practice in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Sounds more positive.
