SWA or T&E??? | on ElectriciansForums
Discuss SWA or T&E??? in the UK Electrical Forum area at ElectriciansForums.net
A
Adam Smith
Hello all,
I am running a distribution circuit to a sectioned off part of someone's house, I'm going to be running the cable under the wooden floor and dropping down in to the room from above. I can use either 10mm SWA or 16mm T&E to achieve this but was just wondering what people think would be the easiest cable to try and pull through joists and what not?. I assume neither option is going to be huge laugh!
Oh no, not again
  • [ElectriciansForums.net] SWA or T&E???
Perfectly aware of what cables are sufficient for the task, thanks. Was merely asking for an opinion (related to the question in hand obviously) as I've not pulled SWA or 16mm T&E through joists before.
Also, I'm qualified. Thanks again.
Reply to SWA or T&E??? in the UK Electrical Forum area at ElectriciansForums.net
Does it really actually need earth sleeving inside the tube? I know it feels a bit bodgy but what's going to happen and isn't an unbroken...
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
