SWA or T&E??? | Page 5 | on ElectriciansForums
Discuss SWA or T&E??? in the UK Electrical Forum area at ElectriciansForums.net
A
Adam Smith
Hello all,
I am running a distribution circuit to a sectioned off part of someone's house, I'm going to be running the cable under the wooden floor and dropping down in to the room from above. I can use either 10mm SWA or 16mm T&E to achieve this but was just wondering what people think would be the easiest cable to try and pull through joists and what not?. I assume neither option is going to be huge laugh!
Notch out the tops of the joists and lay it in.
never figured you for a plumber. 1" holes drilled straight and in line, 10mm SWA, 2 blokes, a bloody doddle to thread in.
Reply to SWA or T&E??? in the UK Electrical Forum area at ElectriciansForums.net
Does it really actually need earth sleeving inside the tube? I know it feels a bit bodgy but what's going to happen and isn't an unbroken...
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
