SWA problem | Page 2 | on ElectriciansForums
Discuss SWA problem in the DIY Electrical Advice area at ElectriciansForums.net
BAD idea. Without going into huge amounts of scientific detail, this way of doing it will induce current into the armour/earth and potentially create excessive heat at the termination ends (assuming the cables are terminated into a steel enclosure of some sort). This idea needs binning off and so does the electrician that proposed it because he hasn't a clue what he's doing!
i know what i wanted to say, but didn't know how to say it. Cheers…………..Howard
You're going to run into voltage drop problems, especially if you put a heater or two on in the cold weather.
Not much more than 12A per 4mm² cable to drop 5% over that distance.
Reply to SWA problem in the DIY Electrical Advice area at ElectriciansForums.net
Sounds more positive.
