SWA Resin Joints - is it ok to use them above ground? | on ElectriciansForums
Discuss SWA Resin Joints - is it ok to use them above ground? in the UK Electrical Forum area at ElectriciansForums.net
bleach
Hi
Is it ok to use them above ground, cables clipped along a wall? I have not used them before and was wondering if they are UV rated etc and do the armours of the SWA still connect in the resin joint to keep the cpc continuous??
thanks in advance
Hi
thanks in advance
Of course the armouring of a SWA cable remains continuous, normally either by tinned copper braiding tape or by a wrapped braiding mesh.
Is this cable and joint just laid on the ground, or is it being supported on a wall or something?? If this cable is being clipped/cleated to a wall or the like, you'll need to purchase a couple of joint supports/hangers, those resin joints can be heavy and over time put tension on the cable ends.....
Reply to SWA Resin Joints - is it ok to use them above ground? in the UK Electrical Forum area at ElectriciansForums.net
Ask your electrician when they do a site visit as to what is required they can also notify the installation to Building Control under Part P of...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
