Swa through scaffold | on ElectriciansForums
Discuss Swa through scaffold in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
My work is erecting a scaffold as part of rough cast project.There is a SWA on the house which is enclosed in steel capping.
Does the scaffold require to be earthed as under fault conditions the scaffold would become live?
It might be a concentric cable so my understanding of this is that if the cable was to be damaged then the earthing of the cable would be too therfore creating an earth path similiar to SWA so would the protective device not operate under ADS anyway?
Or because it is an extraneous conductive part should the scaffold be earthed regardless.
Seems resasonably specialist if there is a guidance note for scaff as above ^^
But I always ask myself 2 questions. Is it extraneous or part of the electrical installation. If yes to either it's required.
SWA enclosed in steel capping, sorry mate don't understand why would someone install a SWA and
Reply to Swa through scaffold in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sounds more positive.
That was my saying not long ago about TNS to PME system. I would be nice you can ring up the DNO, will the systems being up graded, there is a...
