SWA to garage on PME supply and advice needed on earthing | on ElectriciansForums
Discuss SWA to garage on PME supply and advice needed on earthing in the Australia area at ElectriciansForums.net
T
timmy123
I am looking from some advice regarding installing an SWA cable from a house to a stand alone garage some 20 metres from the house. The incoming supply to the house is PME. I understand that I will need to put in a seperate earth electrode for the garage installation. I am installing a seperate CCU in the garage.
My question is regarding the earthing in respect of the SWA.
Do I connect the SWA earthed sheath to the MET in the house CCU or do I connect the earthed SWA sheath to the garage CCU MET which will have an earth via an earthing rod buried outside the garage?
I would appreciate any advice on this as reading the regs etc has not helped me find the answer.
Many thanks​
Many thanks​
yes connect swa armouring at the supply end if you are going to use a rod at the garage end then armouring should not be connected to c/u in garage dont forget treat the garage as a tt system and use a front end 30ma RCD
Hello all, poss my first thread on HERE, I was going to ask a Similar Question , even after 20yrs in the "trade"( LOL now a days!)
With PME, as the Neutral is Earthed, and that Neutral/Earth Conductor breaks / gets damaged somewhere along the line! then you have no reliable or means of Earthing! ................BUT WHY EARTH THE SWA (example) to the TT System in the Garage/shed etc etc,
and NOT keep them separated? I've always known it to be good pratice, EARTH the Supply cable, BUT DIVORCE at the Shed/ TT side
Reply to SWA to garage on PME supply and advice needed on earthing in the Australia area at ElectriciansForums.net
Sounds more positive.
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
