Hi guys,
Can I ask you a DIY question?
I'm refurbing a detached garage and adding a garden building. Garage currently has a submain supplied by 10mm T&E on catenary from the house. I want to replace this with buried cable from house to garage submain, and from garage submain to garden building. Garden building is 10m from house, with garage between the two. It would be useful if I could lay the cable while I'm doing groundworks, then I'll get a pro for the installation.
Our house is heated by NSH on E7 so I would like to extend this to the garden building and the garage. Question is, do I need to run TWO cables from the CU in the house - one for daytime and one for E7? Embarrassed that I don't know this but I don't.
Also, any thoughts on size of SWA? It will need to supply lighting and sockets for six small rooms, plus 5 x 2kW NSH, plus one on-demand bathroom heater (1kW). Water will be heated by LPG.
Thanks for reading this far - advice appreciated!
