swapping a socket | on ElectriciansForums
Discuss swapping a socket in the DIY Electrical Advice area at ElectriciansForums.net
A
aland13uk
hi I was wondering if it was possible to change a switched fused socket to a double socket . The switched fused socket currently has one wire going in and two cables coming out one goes down stairs and runs our tv/ virgin box dvd player etc. etc. and the other goes to centralheating combi boiler. The reason for asking is I would like to plug a hdd hard dive which will be connected to a cctv camera and this would make it all nice and neat in a cupboard out the way.
thanks alan
best off getting a local electrician round to physically see the arrangement, as there may be more than one way od achieving what you want. doing it right and safe should not cost much.
Reply to swapping a socket in the DIY Electrical Advice area at ElectriciansForums.net
It depends on where that SFU 'sits' in the circuit. If it's there as a courtesy isolator for the fridge socket then potentially yes as it could...
