J
johnsimpson
Hi all, I am looking for a little bit of advice if you don't mind...
I have recently purchased a new build home and we have installed some new lighting in the kitchen/dinner and I want to change the normal switch for a dimmer switch...
Currently the normal switch has 2 switches on and I have bought a 2 switch dimmer to replace with.
When I took the switch off the wall I am a little confused as to the wiring, I tried wiring it up exactly the same from the switch to the dimmer but it the lights wouldn't work when I put the power back on.... I don't want to start swapping wires around without a little advice.
If you look at the images I have taken a pic of the existing light switch which works, I am not sure how clear it is but the neutral blue wires are all joined in a connector and not in the switch at all, the brown live wires are connected to the L1 and L2 terminals and a separate wire is going from L1 to L1
Here is a pic of my new dimmer switch
Please can someone advise to how I need to wire this up? Or should I just bite the bullet and get an electrician in?
many thanks in advance!
John
John
