dragon-av
Right chaps I have a job next week which includes all the normal stuff......
The property has an indoor pool in freestanding building in the garden, It looks lates 80's early nineties construction, once you are through the door the pool is open water at the door end are 4 cubicles panelled walls bu no ceiling! 2 contain shower trays, one is a WC and the 4th (nearest the water) has the boiler, pool pump, a 12V 25A Transformer! and a load of spurs! on the wall between the WC and the "plant" is anormal double socket, the pool room has its own panel (above the entrance door) its full and i am pretty sure not RCBO/RCD....
Now I need to install an amplifier in the pool area to run 2 pairs of speakers one in the pool and one outside for the terrace.
HELP! IMO the house needs a rewire as the previous owners had some bad work done the new owner aren't having a full rewire.
Does the plant room count as a special location? Can i use the existing crazy dangerous socket? Can i fit an IP rated socket in the plantroom?
40+ Views and not one comment? Anybody care to assist?
