Swimming Pool Room | on ElectriciansForums
Discuss Swimming Pool Room in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
jagslaglil
Hi,
Anyone know in layman's terms the regs. on installing electric under floor heating to the surrounding floor of an indoor swimming pool please ?
Cheers
Jag
If it's an indoor pool and heated Id go for a wet system and use a loop from the heat exchanger
Thanks Bugsy ,but unfortunately that is not an option as they have not allowed enough depth for a wet system( cock up) ,as this would be a doddle otherwise
If thats the case Id use the warm up system ( if its a decent system they will pay a site visit and do the design ) and all of section 702 & 753 will apply , ADS and possibly an earth mat
Reply to Swimming Pool Room in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Assuming the issue is because you want both to be switched via the same receiver you could always use a contactor to switch the load and use the...
G
Waterproofing options for new shower room Hi, A newcomer here and thank you to anyone with the patience to read my drivel. I am renovating an...
Givey Tago
G
