J
jonathan9468
Hi all
Going to look at a job on monday which is to put the power into the plant room for a friend of mine who is building a indoor swimming pool the main surply is 25m from the plant room and the need a CU in plant room for lights and pool accessories looking at spec the total running amps are around 30amps in total what size swa would you run to the cu in the plant room as they are thinking about using the cu to power outside lights and outside socket in the future and maybe a shower
cheers
jon
cheers
jon
