Switch Fuse Question | on ElectriciansForums
Discuss Switch Fuse Question in the Australia area at ElectriciansForums.net
F
fry80657
Hi there,
If I'm running a 16mm Steel Wired Armour cable up to consumer unit which is 10 meters away (cable will be mechanically protected0, what size switch fuse shall I protect it with? 60A, 80A, 100A? Or are any of them okay?
To be honest, that is a very basic question which you should know the answer too, even if just starting out in college!
Find the rating of the cable and then fuse down from that.
IE cable rating 70amp, then fuse at 60amp.
Good luck with terminating!
Reply to Switch Fuse Question in the Australia area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
For a TN system neutral is deemed at earth potential.
