switch fuse sub main | on ElectriciansForums
Discuss switch fuse sub main in the Australia area at ElectriciansForums.net
B
blenki
Hi,ive got a new garage connection to do,im going to put a switch fuse in after the meter and a henley block ,question is, does anyone know any small switch fuse units i can attach an SWA cable to.Thanks
Reply to switch fuse sub main in the Australia area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Obviously you need to check the means of earthing, Ze, and polarity no matter what for the EIC. As above, if anything looks dodgy then EICR is a...
