Switch Fuse ??? | on ElectriciansForums
Discuss Switch Fuse ??? in the Australia area at ElectriciansForums.net
M
Murdy
Afternoon all,
First time i've posted a thread even thou I've had many hours of entertainment viewing others threads !!
Whilst looking through various threads I've often wondered ( forgive me if its me being dim ) when extending meter tails over 3 meters what's the point of the switch fuse ?
For example is it assumed that because you are extending beyond 3 meters then there is a higher probability of the cable being damaged and so the fuse is used as protection ?
What rating would be used in a domestic premises ?
As I said earlier forgive me for being dim but I've never had to extend tails !!
Afternoon all,
Thats just about it in a nutshell. Generally you would fit a fuse of lesser rating than the cutout fuse, usually 80 or 60amp, and as you rightly say it is to protect the suppliers fuse and cable.
Reply to Switch Fuse ??? in the Australia area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
Red fp200 gold and white FP200 from Pyrsiiam are both UV rated. That said they both eventually show signs of being outside and I used to avoid...
