Switch in brick wall door opening | Page 2 | on ElectriciansForums
Discuss Switch in brick wall door opening in the DIY Electrical Advice area at ElectriciansForums.net
That existing chase looks to be more than 150mm from the corner. If it was less than 150mm, it would be in a prescribed route (safe zone).
The fact that the corner stops at the top of the door, rather than at the ceiling, should not then mean the prescribed route also stops.
I'm with Tel on this...again! Quinetic switch, put it anywhere.
Are these the ones that you installed in the shed?
Yes JK, the very same, and what a lot of fuss they saved. fast, no switch drops, less cable = worth the extra cost!
In that case, I'll second Tel's recommendation.;)
Have a look at the quinetic wireless range.......you could have the switch anywhere you wanted..... go to the TLC website.....have used these myself and can recommend them
Thanks yet again for the really informative set of replies and hopefully also of use to others - I did quite a few searches on this topic and couldn't find anything.
I've read more about the Quinetic switch. It being so popular here says quite a lot I think. I must admit I was slightly bowled over when I realised there are no batteries since it uses kinetic energy from pressing the switch. I guess though they are of even more use to electricians because time is money where as for me I can drill/chase/make good free of charge.
I was going to fit the DP for the outside light higher up in the reveal but since it won't be used very often, maybe I could put it at the back of the cupboard(?) That would then make a lot more sense to fit a Quinitic.
I don't have the full regs but I did re-read my on site guide again (18th) and it did seem to suggest that any corner internal or external is in a safe zone as you suggest. That said it does show a diagram with a door reveal but does NOT show its external corners being in a safe zone.
I don't mind spending money on the Quinetic but with the DP switch to fit which is obviously wired, I'm not sure what is for the best.
quinetic... and put the D/P switch in cupboard. if the outside light is on a sensor, then the switch is just for isolation purposes.
Right! That's it then - always like a decision. I'm going with that!
Please nobody else give me any alternative LOL.
Thanks once again for all replies. All have been very constructive. What a brilliant forum !
What price is the quintec? Are the receivers dimmable & what price is a transmitter & receiver?
I use click smart for this sort of application but it is pricey.
think quinetic receivers are about ÂŁ30 and switches ÂŁ20+. look on TLC website.
Your welcome
cheaper alternative . i'm going to order one and see if they're any good. not much outlay for a punt:
Do they do kits that don't use screws for the lighting wiring?
Would be good if they did a maintenance free version.
Reply to Switch in brick wall door opening in the DIY Electrical Advice area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
