Switch is switching the wrong light | on ElectriciansForums
Discuss Switch is switching the wrong light in the Lighting Forum area at ElectriciansForums.net
Zaidee
Fife
I have been asked about a switch unit in a hall which has a switch for the hall and another for an outside light. After changing this switch to a sensor switch everything is working fine apart from when hall light is switched on it switches the bedroom light on as well.
[ElectriciansForums.net] Switch is switching the wrong light
More information and a couple of more clear photos will give more to go on. Is this the old switch and what does the sensor switch look like. Thanks
I have not physically been to this job or had anything to do with it until the problem arose. Just had another look at the picture myself and it looks like the loop is across the l2 and not the common. Will get the owner to change that. Could that have caused the issue?
Reply to Switch is switching the wrong light in the Lighting Forum area at ElectriciansForums.net
Thanks again for your help, now solved 👍
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
