Switch on a Hager BS4293 RCCB? | on ElectriciansForums
Discuss Switch on a Hager BS4293 RCCB? in the Australia area at ElectriciansForums.net
richy3333
Mentor
Supporter
Far North Scotland
Hi All.
I've been undertaking a PIR/EICR and the property has a load of old Hager BS4229 RCCBs on various boards. Can anyone tell me if this is a switch on a Hager BS4293 RCCB and if so, what it is for? I've spoken to Hager and sent them the photo and they don't know?! The switch is to the right of the 0/off position:
[ElectriciansForums.net] Switch on a Hager BS4293 RCCB?
Hi All.
Of course it's a switch!!!! what do you think the I/ON and O/OFF positions are there for??
Errrr!! Maybe, the switch is there, ...to turn the unit on and off!!!
Just to clarify for those looking at the picture - there is what looks like a small black switch by the 0/off position. It looks as though it can be slid up and down? Naturally, I am familiar with the rotary isolation switch
Turns the RCD function off would be a good guess!!!
Do an RCD test on it, ...with it switched up, and then with it switched down.
That should confirm or otherwise....
I tried Eng54. I couldn't get the 'switch' to move and didn't want to risk breaking the unit, particularly as they are no longer available. The unit also failed to trip at all when tested. Hence the reason for asking on the forum to see if anyone else knew what it was for?
If the unit is U/S, there is no harm done trying to force it to move, as in it's present state your going to have to replace it anyway.
You may find the new style unit will just fit into the old position with little or no juggling ... lol!!
Hi Tony.
Many thanks for your clarification. Do you know what it is supposed to indicate? If I turn the RCCB off/on the indicator doesn't move. Likewise it doesn't budge when RCD tested? Whilst I was around before the 17th I've not come across this unit specific unit before, hence trying to seek clarification.
As to why it doesn’t move I don’t know, it should do. These units are donkey’s years old. I remember them from my apprenticeship days.
Like most things they got relabelled I remember them as Hackbridge Faraday
I think that like me age has caught up with it.
The first “sensitive” E/L unit I fitted was a 3ph 60A 500mA unit. It was the size of a house brick!
My first house had two Crabtree 60A 500mA units feeding two Wylex 8 way boards, it was that modern! But it was bang up to date for it’s time. That was the 13/14[SUP]th[/SUP] edition, I can’t remember which.
My best guess is still a switch, you can clearly see the nail bars there. Still think that this switch is in the sensing coil circuit, to remove the RCD function, thus making the unit a standard isolator switch. Can't see what this would indicate if it was an indicator, the main switch on the unit would indicate itself when tripped or off. At the end of the day i don't know, and my guess is as good as anyone else's...lol!!
Whatever this switch or indicator is for, the unit is old and not functioning correctly so will need changing for a new RCD device no matter what it is....
Reply to Switch on a Hager BS4293 RCCB? in the Australia area at ElectriciansForums.net
