Morning All!
Looking for some one to sense check a wiring diagram I have made for a switch panel in my car.
Ok so helpful information -
All switches are 3 pin LED toggle switches. I would like them to light up when activated.
The LEDs Circuit is currently in the car wired like they are in this and working.
Fan - The green cable is the existing wiring loom. I will be cutting the button off the end and re wiring it to the relay - Therefore just completing the circuit>
Map Switch - this needs to ground a pin on the ecu. On my diagram the ground from 30 and 87 look to join together, they wont be, it'll be two seperate cables.
Show Mode - Much like the Fan one. At present there is a button where the Blue wires connect. So would be just completing that particular circuit again.
Pink wires is the Accessory pin on the switches.
Does all this look correct?
