Switch spur behind fridge what can you do | on ElectriciansForums
Discuss Switch spur behind fridge what can you do in the UK Electrical Forum area at ElectriciansForums.net
Delboy247
I installed a switch spur behind fridge customer was not impressed, but what can you do in this situation I assured him it was perfectly fine, no cupboards next to fridge only way round it to make the fridge sit flush anyone else had a situation like this.
Nothing actually wrong with it as such, other than the customer may feel that if they ever want to replace it, or it needs to be removed for repair/new floor etc., they would then need an electrician to disconnect it.
I know that everyone has their own preferences, but I like to keep sockets in the fabric of the building, so will put the socket either behind the appliance (if there's room) with an isolator above the worktop, or behind an adjacent cupboard and cut a hole in the back for access. I realise these options weren't open to you and you did what was necessary, so you could always appease the customer by offering to disconnect it for free if that's ever required.
I believe it is customary to install the switched fused spur above the worktop, controlling an unswitched socket outlet under the worktop which the fridge plugs straight into.
.... Unless it's a trick question?
I'm guessing that as it's not a built-in appliance, the OP intended to install just a socket, but as the fridge turned out to be deep one, was trying to help the customer out by fitting a SFS instead (lower profile than a plug and socket).
If you had reason to install it that way it's down to you to explain to the customer why you've installed it that way. You could end up in a massive argument which will end up with you saying 'well if I could have done that then I would have.
All part and parcel of dealing with the general public I'm afraid.
Reply to Switch spur behind fridge what can you do in the UK Electrical Forum area at ElectriciansForums.net
In the mind of someone lying there wide awake at 3AM, just about anything.
