switch using water | on ElectriciansForums
Discuss switch using water in the UK Electrical Forum area at ElectriciansForums.net
Mancheser UK
I want to use water to switch on a 12 volt buzzer in my car. A container with 2 contacts, when water is added the circuit is made and the buzzer sounds. Is this possible ,practical. Your help will be appreciated
What is the exact purpose of this engineering project?
[automerge]1577724592[/automerge]
Got me baffled
Water sensing circuits are available as product, from literally pennies for a hobby grade circuit, up to hundreds of pounds for an industrial unit e.g. for boiler water level control. Beware any uber-simplistic approach that puts DC across the electrodes as this causes electrolysis; all proper circuits use AC. Note that there are other ways to detect the liquid that don't pass a current through it, such as ultrasonics (e.g. Squing), optical, and the good old float switch.
Just search for water level sensor!
Reply to switch using water in the UK Electrical Forum area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
This is an RSS feed of thread: Banging on mains water pipe, could an issue with the water mains cause it? Content of the thread: Hi everyone, for...
