Switched Fuse Spur | on ElectriciansForums
Discuss Switched Fuse Spur in the UK Electrical Forum area at ElectriciansForums.net
UK
Wiring cooker hood into a switched fuse spur with a 13amp fuse in the spur. The cooker hood is 3amp. Should I swap out the 13amp fuse in the spur with a 3 amp fuse?
[ElectriciansForums.net] Switched Fuse Spur
Instructions for the hood should tell you what fuse protection is required, but as a general rule a 3A would likely be the best choice.
Reply to Switched Fuse Spur in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
OK. Asking such a basic questions as this (and the answer is simple and I'll provide it in a second), my question to you is do you feel capable...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
