Switched fused spur | on ElectriciansForums
Discuss Switched fused spur in the Australia area at ElectriciansForums.net
K
kduck
Hi,
Just a quick question can you put a switched fused spur in a bathroom outside the zones 1 & 2.
Cheers
I looked at a job the other day the combi boiler was in the bathroom with a switch fused spur next to it. my first reaction was no switch's in a bathroom, but you see towel rails all the time with switch fused spur on them in a bathroom. But then why are fan isolator either pull cord or outside the bathroom.
must be dodgy info here... unless it's selv or pelv... you can't put a sw/fused spur within 3 m of zone 1?...
check regs 701.512.3 and 701.55
230v socket outlets are permitted 3m beyond the horizontal outside edge of zone 1. 701.512.3
Switched fused spurs are permitted outside the zones.
Reply to Switched fused spur in the Australia area at ElectriciansForums.net
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
The pics you put up of the consumer unit are all good .....all circuits RCBO protected and as above swap the fuse out for a 3 amp
