K
ktech
Can anyone point me to the part in the regs that explains when the neutral needs to be broken for isolation.
I'm looking in the case of a three phase sub board main incoming switch - when to use 3 and when to use 4 pole. And isolator switch for fixed appliance, again 3 phase - linked neutral or 4 pole switch.
I seem to remeber that if you have PME this has some effect due to the supplier not been able to guarantee the neutral is at earth potential?
