switching LED strip lights | on ElectriciansForums
Discuss switching LED strip lights in the UK Electrical Forum area at ElectriciansForums.net
T
tommysmith
The wife is requesting LED lights under the bed, its all wired in to the light switch by the door as she did not want a remote control, I was just wondering what people thought about switching a transformer this way ( chopping of the plug or swapping for a round pin one ) or using an LED driver. The lights I am getting are the 5mte LED strip ones that will fix on the underside of the bed. Thanks in advance for your comments.
The wife is requesting LED lights under the bed...........
Are you going to fit some hydraulics as well? Get bouncing! :smilielol5:
[ElectriciansForums.net] switching LED strip lights
If it was me putting led lights under the bed (they would compliment my mirrored ceiling and tigerskin carpeted walls come to think of it) I would probably just get a plug in set and operate it with the switch on the bedside socket.
Is this a wind up unistrut to fix a bed down? try these sound to light led strips should make it interesting.
Your wife seems very demanding in the bedroom and wants a switch? Why not just feed from the switch to a 5a 3pin socket MK K771WHI 1 Gang 5A Round Pin Socket Moulded White (MK Logic Plus) | K771WHI | MK | Sparks Direct near the bed and plug in the driver from there using a 3 pin plug (like they did for lamps before the advent of remote control) then the bed can be left as it is.
Ha ha didn't think this through before asking this did I, uni feet for the bed is a great idea I think, my tiger skin is on the ceiling and she's very demanding, in general tho will look into the hydraulics for a future project
It takes all sorts I suppose.
Reply to switching LED strip lights in the UK Electrical Forum area at ElectriciansForums.net
If you google '4nway led driver' youshould find something suitable. As mentioned make sure the driver is rated higher than the wattage of tape...
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
