M
MarkP
Hi guys. I went to a property yesterday where the guys have walked off site. The first fix has been completed and the property has been plastered. I've tested everything (IR) and everything appears fine but I've found a problem. In the main bedroom there is a main light and two wall-lights which you can switch on via a pull core. They weren't previously connected in the jb in the loft. On connecting the wall-lights first to the jb in the loft they worked first time but after about 5mins of them been on there was an almighty bang and all the upstairs lights tripped out. I then disconnected them from the jb and u/s lights work fine again. Any of you guys have any ideas what could be the problem?
On past experience when stuff goes with a bang it's normally a short circuit but I can't understand why they'd come on for a bit then go.
