Discuss Switching maintained emg lights in the Australia area at ElectriciansForums.net
Hi , Thanks for the reply. I've wired a permanent supply for the emg and a supply for sensor which will have its switch wire to the lights for normal operation. I guess my only question is in regards to the neutrals. Are the neutrals for the emg the same as the lights? As current have its own that go back to the switchboard
So just to clarify,
1 supply cable for sensor (neu, earth, active)
Switch wire from sensor through lights (neu, earth, active)
Our regs stipulate that emg lights/exits must be own circuit.
I was running a supply cable back to the switchboard for exits also .
I keep confusing myself ??
Thanks, I intend on keeping the emg lights switch wire on with the normal lights. I'm planning to run a single active from my exit lights to the emg lights as a permanent active.
I thibk the ting that confused me the most is, is it ok to run the switch wire for the emg lights with the standard lights.
Hi Dave,
I only intend of having the light switch cable terminated at the fittings, i wont be using 2 differnt neutrals
I will have a separate hard active for the emergency so the battery can charge
Reply to Switching maintained emg lights in the Australia area at ElectriciansForums.net
