Hi Folks
I'm testing a factory where a lot of circuits are wired in SY flex. The metal glands have not been fitted, just normal pvc compression glands and the metal braid on the flex has not been earthed.
The problem is, between the unearthed braid and the earth terminal in the DB, im getting between 24-50v only when the cable is energised.
Is this the copper cores inducing an EMF in the braid? if it is, then i thought that the live and neutral within the flex would cancel out the emf produced.
If its not this, can someone please explain??
