M
minty
My house is fairly well loaded and we have now decided that we want to swap over from a gas stove to a duel fuel cooker. I am concerned about the load that this would present and wondered what would be the best way forward. Our house currently has a 60 amp company fuse and running currently on that is a 10.kwh shower drawing 41amps, a single split Air Con Unit used infrequently drawing 6.9amps, Kettle drawing 10 amps, Washing Machine drawing 8 amps and a dishwasher drawing 11 amps, obviously none of these are used all at the same time but if we add this duel fuel cooker rated at total load of 4.5 kwh that would draw 19 amps if both ovens were in use at the same time, given the fact that the two largest loads would be the shower and cooker using any of the other appliances would tip this over the 60 amps available.
I have spoken to my electrical supplier EDF and they require a Load Survey to be compiled by a Qualified electrician and then would make a decision as to if the house fuse could be uprated to a 80 amp pending on if the line in ( Cable in ) would be up to the job and if not a new line in would be required at considerable cost.
Some people have said just get the new cooker and see how you go but I do not want a situation where I although it would be possible for us to juggle loading i the event of say my kids using stuff when we are not at home cold result in the 60 amp fuse being breached.
Would a 80 amp provide the necessary head room for this loading or should I just get the new stove and see how it pans out ? Also EDF have said I may be required to upgrade the meter tails if they give the go ahead for a 80 amp fuse, would EDF pay for this or does it fall to the householder ?
Any Advise welcome,
Any Advise welcome,
