W
WRDEnergy
Hey all,
This might be slightly weird but bear with me.
I am doing an install on Monday and I have designed it based on the SMA sunny design software, I saw that if i used 12 218watt hyundai panels I get a 99% efficency using a 2500HF-30 and if i use 6 220watt hyundai panels on a SB 1200 i also get a 99% efficency.
so i have 2 roofs 1 i was going to put the 12 panels and the other the 6 panels this is all on 1 house but has 2 sections to the roof... I know i have a almost perfect inverter choice but my questions is this.... can I combine the AC side from both inveters into the same generation meter... or do I have to use 2 generation meters ? parts for me are not a problem but I have never done a build this way.... I know techinallly both inveters will be giving out 230v 50 hz but like i say i dont know if its good to combine them
to confirm i will have both go into the generation meter then have just 1 go to the consumer unit (basically joining them in the meter)
Any advice on this would be great.
thanks
thanks
