System Tripping
C
chippysparks
Hi Guys,
I have a heating system that keeps tripping the breaker out, every time the spur is switched on.
I am set to fault find it tomorrow.
Are there any things that usually cause this on a heating system?
Cheers Chaps
P
cheak the pump and zone valve if its a heat only boiler most faults are unseen water leaks so check for water marks on boiler controls.
start off with heating and hw controls switched off,ie no demand,that might narrow it down to the programmer,or controls when demand from programmer,had a faulty roomstat cable a couple of weeks back.
