t@e in conduit? | on ElectriciansForums
Discuss t@e in conduit? in the UK Electrical Forum area at ElectriciansForums.net
Sparky28
Hi all, query, I need to run a cable (s) and I was thinking of running a piece of 1.5mm in a piece of 20mm conduit approx 2 meters before going into a stud wall.
Just wondered what ideas are out there ????
Cheers
I've put T&E in plastic conduit, straight runs are fine, also the odd bend if you bend the conduit using an internal spring.
But trying to use the bends you can buy doesn't work, they are too small a bending radius and cause the T&E to coil up and/or jam, as you'll see if you try it.
Nothing wrong with T&E in plastic conduit, rather than conduit cable, if that's what you are asking. It's just more expensive to do it that way, but if you already have it, and no conduit cable, then go for it.
he's got to use T/E as it's partly in a stud wall and whatever without conduit, so he cant use single insulated singles. nowt wrong with T/E in tube, but as snowhead said, thread it piece by piece and you can use bends then.
You may as well have asked " does anyone know the winning lottery numbers for next week?"
You don't do you??? Just asking...? Just tell me five of them if you want to keep the jackpot to yourself.
Reply to t@e in conduit? in the UK Electrical Forum area at ElectriciansForums.net
Does it really actually need earth sleeving inside the tube? I know it feels a bit bodgy but what's going to happen and isn't an unbroken...
Job interview View: https://www.youtube.com/watch?v=uYKD1j5jEvs
