Doing up a workshop with offices out the back.
The supply is in the offices, as far as you can get from the workshop.
There is now a change of use in the workshop, and there will be some quite hefty stuff moved around.
In the workshop area all the current electrics are in T&E clipped direct to the timbers and breeze block walls.
I have advised that it is all pulled off and put in conduit for mechanical protection.
The bloke says thats a good idea (even he could see what state the last occupier left the cabling in).
He also says 'I want a light here, here and here all individually switched from one switch grid'.
What he wants doing will be a nightmare in T&E.
So can I use a junction box to convert the 1.0 T&E to 1.5 singles (wago connectors probably) and go from there? I really don't what to have to run conduit all the way back through the building and offices.
