T5 ballast wiring | on ElectriciansForums
Discuss T5 ballast wiring in the UK Electrical Forum area at ElectriciansForums.net
Javier256
Michigan
Hi guys first time posting. I have a spare 28 watt 2 bulb T5 ballast. I purchased the wrong single bulb T5 fixture and cant return it as it was a clearance item.
Can I take my spare double bulb ballast and somehow wire it for my single bulb fixture so instead of running at 28watts, it would run at 56 watts?
I’ve attached a photo and any help would be appreciated.
Thanks!
[ElectriciansForums.net] T5 ballast wiring
Reply to T5 ballast wiring in the UK Electrical Forum area at ElectriciansForums.net
You really need an inductance or LCR meter or a ring tester which are expensive to buy but you can make your own ring tester if you want a project...
