- Joined
- Jan 21, 2011
- Messages
- 581
- Reaction score
- 57
hi there
customer has requested a T5 fitting (21w) fitting to be fitted to fitted wardrobes. now i plan to wire the light via sw fused spur (fused at 3 amps) to a local socket on the downstairs ring main. now ive noticed that the power cord supplied with this type of fitting is only 0.75mm flex which im sure is good for 6amps. i will probbably have to extend the this via junction box.
i usually use 1.5mm for lighting would it be acceptable to just use 0.75mm flex direct to sw fsu ??? as the power cord supplied is only 0.75mm. again fused at 3amps so cant see why not
any thoughts
any thoughts
