Table 4D4A | on ElectriciansForums
Discuss Table 4D4A in the UK Electrical Forum area at ElectriciansForums.net
P
PhilB
What does the "r", "x" & "z" mean on the mV/A/m columns from 25mm SWA downwards. I can't locate it in the regs anywhere.:confused:
Thanks to all the replies and the associated link I can kick on from here. I did know the volt drop formula as I do it quite a lot but not above 16mm for some time now. As I'm now the wrong side of 50 new information takes just that little bit more time to process up in the grey matter :confused5:
Reply to Table 4D4A in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
Written in clauses are essential, but should be fairly standard fare to a solicitor. A similar situation exists around where I live with regard to...
