Tail Size | on ElectriciansForums
Discuss Tail Size in the UK Electrical Forum area at ElectriciansForums.net
L
leitrim99
Hello all,
I am installing a 63 amp 2way CU with 16 mm tails for a loft conversion is fitting a 10mm earth tail. The main CU is a 6way fed with 25 mm tails and 16mm earth. Thanks
Hello all,
Congratulations Leitrim, I'm very happy for you.
I think the question is, is it acceptable to install a 6 way CU with 25mm tails and a 16mm earth.
I thought we live on Deep Thoughts' successor, designed by Deep Thought to determine the ultimate question to the answer of 42.
The question is of course:- "What do you get if you mutiply six by nine", sorry biff55.
Reply to Tail Size in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
