s1m0n
Hi,
I have recently replaced a consumer unit on a TT earthing arrangement.
I went down the local Building control route, no problem so far.
Sent in the completed certificate, but got it declined with this stated on the paperwork.
"TAIL SIZES NOT GIVEN THEREFORE UNABLE TO DETERMINE IF EARTH CABLE IS CORRECT"
I use the certifcates from BS7671 (short version)
I can not see any where that asks for the Tail sizes.
any input welcome.
Confused :confused:
Was it the Electrical Installation certificate you used. If so then it does ask for the size of the supply tails, if it didnt you have filled in the wrong form for the job. I assume the short version you refer to is the one that only requires one signature for construction, design and testing etc, even so this also does have the field to complete for the supply tails size.
regards...........Howard
Hi Sirkit breaker,
it is the one with just one signature for design,constructionand Inspecting & testing,
do you know exactly where on the form,
Thanks in advance
Simon
There is no field for supply tail sizes, only Earthing Conductor and Main Protective Bonding Conductor sizes.
Page 3 of the full EIC has a box for supply details where tail sizes and materials are listed.....
Hi Graeme,
I can only see 2 pages of the Long form EIC, checked in BS7671 regs and GN3
Am I not looking in the right place?
Simon
Are you talking about the same EIC? We're on about the model certificates from the BRB.
Just been right through the PDF and the EIC doesn't have a page 3. Page 3 would be the schedule of Inspections.
Hi to all
where can i download copies of certificates from that i can fill in by computer or by hand as the ones i have are in pdf and cant be altered by computer
cheers
A copy of page 1 of one of my EIC, page 2 is all the usual boring crud also!
Just to add, Simon if you would like me to post you a couple of the complete set of forms I will, these are non 'club' forms as I prefer these!
If you want a couple please PM me your address! Stick a couple of quid in the local charity box to cover postage!
I have never seen that form. The ones i fill in are the full EIC single signature, and these do have the relevant fields to fill in for the size of supply tails, protective conductors and all the rest of it.
Cheers.........Howard;)
You should have seen that form.
It's the one from the back of BS 7671 ;)
Sorry for the confusion, as Im using PIR Form and page 3 (which I thought mimicked the full cert) has the supply info....
Hi
is it possible to get copies of the standard forms in a format other than PDF so they can be adapted and filled in by computer any advice grateful
For £75+VAT (probably the cheapest form software) just buy cet software. Not only does it allow you to quickly fill in the forms, it also double checks against the permissable values for the selections made. The best bit is you have no fear of overwriting a previous file if you forget to "save as" as its all too easy to loose your certs that way.
There are many about, but I like the ease and functionality of PIR Form
Tail Sizes on EIC
s1m0n,
Graeme Harrold,
