solo2771
Hi all I am doing rewire for part P assesment ( was just a cu but no earths in lighting ect)
Anyway its tncs and its on 16mm tails with a switch fuse before the cu as it is about 3.5 M away from meter , am I right in thinking as long as it is fused for 16mm it will be ok?
also i believe I would need a smaller value fuse in the switch fuse than in the main fuse?
another problem is none of the switch back boxes have earthing points do they need them? and if so could I use thefixing screw with a crimped ring on it?
Is it ok to use the earthing bar for MET? and finally for now cross bonding on the new gas boiler (mounted on the wall in the loft)?
Thanks in advance
paul
Thanks in advance
paul
