L
liam b
Hi
I think my options will be limited here but..
I need to run tails from the meter box outside to a CU inside but there is a door inbetween the two.
i cant get into the cavity to run the tails and dont want to run them outside but there is a shower cubicle on the other side of the wall from the meter box, what would you suggest?
this is a new installation
thanks
If this is a new build then i would probably be talking to the architect as it sounds like a classic design problem, either with the positioning of the shower or the meter box, creating a false wall behind the shower may be one answer but length of tail may be an issue, without a plan or layout its hard to see a solution.
i agree with dark wood , false wall sounds the best option as you cant go up the cavity any more , as dark wood has mention the tail length may be a problem you may have to install a switch fuse in the external box so you can protect the tails
Tails from meter to CU
Australia
liam b,
nickblake,
