Tails greater than 3m length.. | on ElectriciansForums
Discuss Tails greater than 3m length.. in the UK Electrical Forum area at ElectriciansForums.net
N
Newbie90
Hi all,
I know tails are meant to be less than 3 metres in length and if not then a switch fuse needs to be installed.
What's the situation when the tails from a flat go from a communal hallway then into the consumer unit? (Approx 5m)
Do you just put a switch fuse next to the meter? (The run goes through the loft space)
Is it only 3 metres if there is no mechanical protection?
The tails are contained in some sort of plastic tubing all the way to the consumer unit.
Distance is a DNO requirement and is generally 3 to 5 metres. Then you require a switch fuse...
Plastic tubing IS a mechanical protection. Tails still need to be insulated and sheathed, as far as i'm aware!! SWA would also conform to to being insulated and sheathed, as well as providing improved mechanical protection....
Bullet> tails > Meter > tails > (Isolator) > tails > KMF > (RCD) > local tails.
Theirs Yours
Reply to Tails greater than 3m length.. in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
