Tails longer than 2m | on ElectriciansForums
Discuss Tails longer than 2m in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
What is the main purpose of putting a SF inline with the main head for running mains further than 2m to location of CU?
I know it must be to do with the operation time of the DNO head but I can't figure out correct terminology.
if tails are > 3m, then it's recommended to fit a switch fuse with a lower In than the DNO fuse in order to protect the DNO fuse from a fault on the tails.
Reply to Tails longer than 2m in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I really can't see a problem with it assuming there is a neutral there.
Yeh that’s my thinking. I have to supply the box so can order a bigger 3 phase option to give myself a bit more room
