taking power to shed | on ElectriciansForums
Discuss taking power to shed in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
isit ok to use plastic trunking outside....
i plan to come from the attic in a bungalow down the outside wall in plastic trunking and run a piece of copex from trunking under blocked pavement to shed.....
reason im thinking trunking is , i can hide the plumbers pipe in the trunking if i section it off
Yeah just clip it, no reason you can't put it in trunking tho, what about coming from loft in t+e in trunking then when you get to ground level stuffing gland it into a dappy box with armoured coming out the other end to shed, be careful that pipe could be a gas pipe if so check the regs on it first
Reply to taking power to shed in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
You should have no problems with what you want but even if you install conduit the cable still needs to be UF cable which is approved for under...
