Teaser... | on ElectriciansForums
  • Thread starter Darkwood
  • Start date
  • Replies 23
  • Views 2K
Discuss Teaser... in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Darkwood
[ElectriciansForums.net] Teaser...
Right I need to see how your mind works ...In the above how many squares do you count?
PS.. Do not qoute this as the answer will change in doing so.
This is one of those multiple answer ones that does the rounds and depends on your angle of attack... within the actual pic itself 16 would be the answer but as I worded it 'In the above, how many squares do you see' this can also be taken as everthing above.
Its normal for the mind to focus on the picture as its the main part of the post but the answer could be argued to be 27 or 28 again depending if you look at the whole including written parts.
16- withing picture
3- full-stops (which in the font style are clearly squares)
8- in the sentence (various)
1- finally the word 'squares'
Ill accept then 16 or 28 ;)
Noted viewers on phones may have difficulty seeing the shape of the small decimals but I did increase the font to help out.
Reply to Teaser... in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Tiling Rates Per Square Meter - How much does tiling cost? Tiling Rates Per Square Meter / Per Day – How much do tilers charge? I know this...
We have been through this debate at my local branch of the Men's Shed charity. It always seems to be the case that if you buy enrty-level gear you...
