R
RichardMoore
Hi am an electrician with the following dilemma. I've installed 9 dimmable led's on a led dimmer but the minimum load of the dimmer is 60 watts. The lamps are 4.5 watts and only have a total load of 40.5watts When I dim them down they do so far then they begin to flicker. But when i install a standard 50watt lamp the don't.my question if I can explain is. If I was to install a resistor at the EOL of the correct size to increase the current thus the load would increase to a significant size to replace the standard lamp and correcting the problem I have also any advice on resistor sizes that may work thanks for any input much appreciated
