Telemacanique DOL spares | on ElectriciansForums
Discuss Telemacanique DOL spares in the Electrical Tools and Products area at ElectriciansForums.net
T
trebor
Hi does anybody know a source of spares for the above starters, these are quite old starters and the part i need is the green start button with the white nylon plunger, RS have spares but not for this model, we have a lot of these installed and I dont really want to change the whole starter
many thanks
Are they 22mm? If so there are plenty around so long as you don't have to replace with other tele gear.
What model of starter is it?
If they are 22mm can you use one of the more modern Harmony 5 pushbutton operators and glue a piece of nylon bar to the back of the button?, even if the bar falls off, it will still fail safe.
failing that if its the type with the plunger on the back it should leave you with enough space to get a push button with a nc contact on the back in
Reply to Telemacanique DOL spares in the Electrical Tools and Products area at ElectriciansForums.net
Yeah when we start up the cone crusher the power factor can drop from .9 to .5. I’ve seen it drop down to .4 during start up. We have more than...
Oh I get that for sure. Here it's not the problem though. The oven is in very good condition, and works well, just the heating element is warped...
