I
iamelectric
need to put 2 extra phone sockets for sky boxes am i right in saying you only use 2-5 , is 3 needed or not , cheers
Discuss telephone extension in the UK Electrical Forum area at ElectriciansForums.net
When PSTN came out (plug socket termination network)the master box had the capacitor witch made the ringing for secondary/ slave sockets on terminal 3.
Yes it is known as PSTN regarding telly sockets in bt,worked for them long enough,so you googled the term ahhh? so clever.PSTN = Public Switched Telephone Network which is the aggregate of the world's circuit switched telephone networks that are operated by national, regional, or local telephony operators, providing infrastructure and services for public telecommunication and not as your definition which may be some internal BT slang
Terminal 3 also stopped the bell tinkle when dialling on the older phones. With the use of ADSL / vDSL for internet connections it's use is not recommended due to inference that reduces available bandwidth in fact if you or BT install an i-Plate at the master jack this will disconnect terminal 3 to the rest of the internal phone network
Reply to telephone extension in the UK Electrical Forum area at ElectriciansForums.net
